creaky's avatar
creaky
Star
Nov 19, 2017
Brief magenta then long blue light on RBS50 satellite
Several times last night the RBS50 satellite would flash magenta briefly and then go to blue for a few minutes before shutting off the lights completely. I'm still getting a connection on the satellite but it's at a slower, inconsistent speed. Been on 2.0.0.74 for weeks and haven't moved the router or the satellite; no new devices added that might create RF interference. Performance when clients are wirelessly connected to the router are solid. I have recently connected our security system to the router via ethernet, but will have to see if disconnecting that has any impact. Suggestions? Reset the satellite?
    • creaky's avatar
      creaky
      Star
      The position of the router/satellite had not changed since the setup of the system so I tried something else that worked: Rebooted the satellite only and resynced it with the router; now speeds for clients connecting to the satellite are back.
      • Retired_Member's avatar
        Retired_Member
        The latest branch (2.0.x) changed the range for the sats, significantly shortening it..
    • creaky's avatar
      creaky
      Star
      djc6: Have you tried power cycling the satellite? That helped with my situation.
      • djc6's avatar
        djc6
        Luminary
        Hasn't helped, problem comes back week or two later.  It never came on first 10-11 months of ownership.
