rp17
Nov 20, 2019Guide
Cameras and other devices not connecting to satellites
I see this issue has been raised and there doesn't seem to be an answer. I have ring cameras all around my house and I have an Orbi base station and 3 satellites. The cameras all have poor signal and it seems most of the time they dont even connect to the satellite that is within feet from them but rather they connect to the base which is fairly far away. Is there a way to fix the signal issues as well as what the devices connect to?
Have you tried using the Ring App to "Change the WiFi Network" and then have it select the Orbi (again) from the list of available networks?
Or, do a "reset" on the Ring and set it up again?
This issue of devices connecting to an Access Point that even the dumbest human knows is inappropriate remains one of the top mysteries. Solving it would improve the Orbi experience immensely.
- rp17GuideI have done both multiple times as well as change a ton of settings within the orbi GUI and nothing helps. Thanks though.
How about this: go to the Orbin web interface, Advanced Tab, Advanced Setup, Wireless Settings and turn the 2.4G transmit power down to 25%. That will reduce the power output of all Orbi radios. THEN try to connect the Ring Doorbell to Orbi. Maybe the Ring thought the router WiFi signal was "poor, but good enough" and reducing power will make it prefer the satellite. The Attached Devices page will show if it changes to a satellite. Afterward, turn the power back up as far as you need to get good service throughout the house.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). - rp17Guide
These satellites seem to be almost useless. I have a smart plug in he's from a satellite and it still is connecting to the main router. There doesn't seem to be any reasoning for the connection and it makes using this almost impossible. I'm seconds away from eating the $400ish dollars I've spent on all this equipment and buying something else
What didn't help?
Please give feedback to the questions presented so we can get a better idea if your configuration and settings please.
rp17 wrote:These satellites seem to be almost useless. I have a smart plug in he's from a satellite and it still is connecting to the main router. There doesn't seem to be any reasoning for the connection and it makes using this almost impossible. I'm seconds away from eating the $400ish dollars I've spent on all this equipment and buying something else
- chadarooskieAspirant
Did you ever find a solution to this problem??? I am having the same issue. It will be connected to the Satellite (which is not 5 feet from the Ring spotlight cam) and have great signal.. then out of the blue it will connect itslef to the main Orbi Router and have harly no signal.
What happens if you turn down the power output on the RBR from 100% to say 50%. Under Advanced Tab/Advanced Settings/Wireless Settings. Camera should remain connected to RBS...unless the RBS happens to be rebooted or power cycled. Then the camera may reconnect to the RBR. Which in this case you'll have to reboot the camera or RBR while leave the RBS ON.
chadarooskie wrote:Did you ever find a solution to this problem??? I am having the same issue. It will be connected to the Satellite (which is not 5 feet from the Ring spotlight cam) and have great signal.. then out of the blue it will connect itslef to the main Orbi Router and have harly no signal.
- rp17GuideI never fixed the issue. I tried everything suggested and still it jumps back and forth. I just deal with it because it seems to work ok the majority of the time
