T-E-R's avatar
T-E-R
Tutor
Apr 24, 2020
CONNECTION BETWEEN THE ROUTER AND SATELLITE
Is the blue light on the satellite supposed to stay on if it is connected or does it turn off.  I have moved the satellite closer and closer to the orbi router and it comes on but then goes off.  The orbi router stays lit.  I ended up putting it in the same room, just a few feet away and it does the same thing.  Is that they way that it works or do I have a defective unit?
