Michael512's avatar
Michael512
Follower
Oct 17, 2016
Disable DHCP on the ORBI
I would like to add a IoT firewall (CUJO) to my network, however they require I disable  DHCP on the ORBI. How do I do that? Or is it even possible? I have the  MAC Addr for the CUJO.
    before you consider the cujo you might just want to read
    http://www.smallnetbuilder.com/lanwan/lanwan-reviews/33018-cujo-smart-internet-security-firewall-reviewed
    being fully could based
    CUJO costs $99, which includes a 180 day trial license. After that, you need to pony up $8.99 / month, $26 for three months, $49 for six months or $80 for a year of service. If you're a true CUJO believer, you can opt for a lifetime subscription for $800.
    so unless you are willing to fork out $800 for the lifetime subscription they gave you trapped
    the dual nat issues are also a concern
    i just think its prob overkill for a home based solution and expensive and cloud based , if you are concerned by security why would you want your data being read or stored on the cloud
    pete
    • dpdurst's avatar
      dpdurst
      Luminary
      From what I see just untick the box that says use DHCP and your then all static assignments. Seems pretty straight forward on the Orbi
        this aproach would see anything connected behind the orbi would have to deal with dual nat , sure it may work for basic stuff but things that need 2 way communications like games and torrents etc etc would have issues
  • You can put it into AP mode, which will disable both DHCP and DNS, but that assumes you have some sort of router/edge device sitting in front of it on your network.  At that point, it will act as nothing but a WiFi bridge to your network, assuming all other services are provided by another device.
    Rodney
