BastideDesCrete
Aug 02, 2020Aspirant
Download and upload randomly drops every 30seconds for a few seconds then reconnects(RBR20, RBS20)
I got my orbi router (RBR20) and 2 orbi satellites (RBS20) in a pack that came together. It was working fine for a long time but up until the most recent firmware update it started causing a persistent problem where it would drop the download and upload speeds for a few second (maybe 2 - 5) and then would start again, this would happen every 30s - 60s. Sometimes if I restarted the router it would be fine, but the next day the problem would reoccur. This problem is very annoying if I were to stream, play games or call someone as my connection would drop so often. Another issue that could be the problem is that it gets quite hot (41*C) and that might have an issue but I doubt it.
I have looked everywhere online but I couldn't find a solution. I have tried rebooting it, factory resetting it and this hasn't impacted anything. I was wondering if anyone knew a solution to this? I assume it has something to do with either the firmware update (which I doubt because I can't find any other posts online) or there might possibly be something wrong with the satellite. I have also tested to make sure that it isn't my computer as I have used mobile data on my pc and it doesn't have the same issue.
I have attached a screenshot of task manager when the connection drops when I'm downloading a game.
Your modem seems to have a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
BastideDesCrete wrote:I have tried the settings that you advised but it all doesn't change anything, I am currently trying to use the most stable configuration that you added as well.
And yes I have done a factory reset after the latest update and this hasn't changed anything.
Sometimes the problem occures, whilst at other times the wifi functions normally.
Here is the other information that you have requested:
Firmware: V2.5.1.16
ISP: Orange
Modem Model: Livebox 4
Modem made by: Sagemcom
Orbi system operating in: Router Mode
Size of home (Sq ft): 3000
Distance between Router and satellites: 10m - 15m (30 - 50 feet)
BastideDesCrete wrote:Another issue that could be the problem is that it gets quite hot (41*C) and that might have an issue but I doubt it.
Page 158 of the Orbi User Manual lists the operating temperature for the RBR20 as 0 to 40C. (32 to 104F). Modern processors have temperature sensors which reduce the CPU frequency when the system overheats.
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Do you have any method of cooling the Orbi? As an experiment, you could put the Orbi in a cardboard or styrofoam box with some ice and see if the problem goes away. (That is obviously not a permanent solution, but would at least allow a conclusion as to whether the temperature is an important factor.
If the problem did not exist before the recent firmware update, another step would be to download the previous firmware from the Netgear support site and do a manual firmware update. (in this case, a "downdate" - hah) It could be that the latest firmware has placed a higher load on the processor which makes it more sensitive to temperature.
- BastideDesCreteAspirant
Thank you for your very quick response, I checked when the problem was occuring and the temperature was below 40*C so I doubt it is thermal throttling. I haven't decided to revert the firmware update as of yet as I would like to try other solutions but I also don't think it would be this because I haven't seen any other posts about this online.
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Has a factory reset and setup from scratch been performed since last update?
BastideDesCrete wrote:I got my orbi router (RBR20) and 2 orbi satellites (RBS20) in a pack that came together. It was working fine for a long time but up until the most recent firmware update it started causing a persistent problem where it would drop the download and upload speeds for a few second (maybe 2 - 5) and then would start again, this would happen every 30s - 60s. Sometimes if I restarted the router it would be fine, but the next day the problem would reoccur. This problem is very annoying if I were to stream, play games or call someone as my connection would drop so often. Another issue that could be the problem is that it gets quite hot (41*C) and that might have an issue but I doubt it.
Firmware: V2.5.1.16
ISP: Orange
- MstrbigMaster
Does this only happen using WIFI? Or do you experience the slowdown with any wired devices?
If it's just WIFI, it could be packet traffic from other WIFI devices or interference. If interference I suggest changing channels.
It could also be an ISP device or connection issue. I had an intermittent slow down of my download speeds going from 500Mbps down to 300 and upload speeds going from 50Mbps down to 4 or 5, right after switching from Velop to Orbi. After resetting and testing the Orbi, I plugged directly into my ISP modem. I still had the slowdown, so I contacted my ISP. It turned out to be a bad Tap on their side. Now my speeds are rock solid.
