fixmacs's avatar
fixmacs
Guide
Aug 16, 2019
Firmware update connection now poor
I updated the firmware on the Orbi router and satellitte today. Now the sateliite fails to connect "good." The connection status is now "poor." I restarted the satellite and re-synced the system. Still "Poor."
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Try a factory reset and setup from scratch on the RBS and RBR...Let us know how it goes.
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • fixmacs's avatar
      fixmacs
      Guide
      No luck. I performed a factory reset of both the Orbi base station and the satellite. The connection begins as GOOD, then after five minutes or so it switches to POOR.
      Everything was working perfectly until the firmware update.
    1. Please make a wifi scan and see which channel the backhaul is currently using. In a wifi scan you will see your wifi network and the used channels and also you will see the backhaul channels as "hidden" networks with no SSID. It can be that the channel used by Orbi is being used by your neighbours or has radar interference.
    2. Please follow the following procedure to forget the current backhaul link and create a new one:
      1. Switch off the Satellite
      2. Go to Attached Devices in the web GUI and click on the "Disconnect" button beside the Satellite in questions
      3. Turn on the Satellite and use a paper clip to factory reset the Satellite
      4. When the Satellite is up after factory reset, press the Sync button on the Satellite and then on the Router
      5. When the Satellite is added it should behave correctly.
    • fixmacs's avatar
      fixmacs
      Guide
      How do I perform a wifi scan? I don't see such a tool in the Netgear Orbi utility.  I cannot find the channel information for any Orbi device, satellite, or connected device.
  • FURRYe38's avatar
    Any progress on this?
      • FURRYe38's avatar
  • Retired_Member's avatar
    Retired_Member
    Why?
