bobselff
Oct 20, 2019Aspirant
Gigabit internet
I have gigablast internet connected to the WAN port. When I run a speed test with the orbi app I'm only show 400 to 500 mbps. Does the Orbi not support gig WAN?
What is the Mfr and model# of the ISP modem the NG router is connected too?Is your speed test wired or wireless? Wired is preferred...
Been some that can get this speed and some that can't.
- bobselffAspirantCox ISP
Netgear Nighthawk cm1100 modem
Orbi RBR50
Firmware v2.5.0.38
Speed test: (speakeasy.net)
Wireless: 437Mbps
Wired: 590Mbps- FURRYe38Guru - Experienced User
What are you speeds with a wired PC connected to the CM modem directly?
- Retired_Member
FURRYe38 wrote:What Firmware is currently loaded?
You forgot to ask about the neighbors
- Retired_Member
bobselff wrote:
I have gigablast internet connected to the WAN port. When I run a speed test with the orbi app I'm only show 400 to 500 mbps. Does the Orbi not support gig WAN?don't use the app
agree with Retired_Member , don't use the app for speedtesting. Also follow what FURRYe38 recommends and make sure to do it with a hardwired connection. Only other thing I can recommend is to directly connect to your modem and see if you have gigabit speeds at the modem.
