dimikagi
May 10, 2025Aspirant
Google Pixel 9 and Orbi Wi-Fi 5 issues
I've had my Orbi setup for years with little to no problems. However, for the past 2 weeks, my Google Pixel 9 Pro phone has behaved like it's on a dial-up modem connection when on my home wifi. It's ...
- Jul 16, 2025
The next Android update on the phone fixed it. I still don't know what happened and Google support was useless.
Jul 16, 2025Guru - Experienced User
Any progress on this?
dimikagi wrote:I've had my Orbi setup for years with little to no problems. However, for the past 2 weeks, my Google Pixel 9 Pro phone has behaved like it's on a dial-up modem connection when on my home wifi. It's fine with five other Wifi networks I use regularly, and its good with just the regular T-Mobile data connection. But it's definitely not happy with the Orbi Wifi.
The last change to the Pixel was April 5th (system update) which was over a month ago, and it was fine for 2 weeks after. I've even done the Pixel 'reset network and Bluetooth settings' option to wipe the config from the phone and start fresh.
On the Orbi, I've twiddled some of the advanced Wifi settings in the config but it's not changed anything. Has anyone else run into this? Any thoughts or suggestions? Other phones (iPhone, OnePlus) seem fine on the network.
- dimikagiJul 16, 2025Aspirant
- FURRYe38Jul 17, 2025Guru - Experienced User
lad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
