dimikagi
May 10, 2025Aspirant
Google Pixel 9 and Orbi Wi-Fi 5 issues
I've had my Orbi setup for years with little to no problems. However, for the past 2 weeks, my Google Pixel 9 Pro phone has behaved like it's on a dial-up modem connection when on my home wifi. It's ...
- Jul 16, 2025
The next Android update on the phone fixed it. I still don't know what happened and Google support was useless.
dimikagi
Jul 16, 2025Aspirant
Jul 17, 2025Guru - Experienced User
lad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
