CharlieB23's avatar
CharlieB23
Got disconnected often
Hi, how are you?
Please help me on this. My situation:
Cable modem from my ISP (with wifi desactivated both 2.4 and 5ghz), connected to the Orbi Router RBK20 via ethernet. Orbi in AP mode... I can see the App working in the Ipad and using chrome at OrbiLogin... In my dashboard, everything is green expect guest network which is yellow. But I don't want it, I don't care. If I intend to enable guest network, I get this error:
"WPS process is in progress, please apply the changes later." ... what is that?
I have this problem. Often, i'm disconnected from the wifi and I can't acces at the OrbiLogin no more...
Every time that I'm trying to use the app, it crashes the internet, I get disconnected from the OrbiLogin.
If I use only the Orbilogin (to test that everything it's working), I'm fine for a while, then some devices are connncted to the wifi but with no internet, sometimes they get disconnected also.
It looks like that only with my Imac, with no wifi, just ethernet connected to the Orbi router, the internet doens't drop
What Can it be? Some settings recommended on my router? I have this modem http://www.ubeeinteractive.com/?product=ubc1310
In the worst case scenario, reset settings and start from scratch, but I won't prefer that not.
I thought that having this my wifi system was flying LOL .. I'm kind of frustrated, nut i'm optimist to resolve it soon.
Looking forward for your help,
Have a great day
  • FURRYe38's avatar
    If it doesn't have bridge mode then it may not be supporting or have a built in router. You'll be fine for now.
    Be sure to ask the ISP to ensure that you don't have a ONT with a built in router when the cross you to Fiber. Just need WAN side IP addressing up to the RBR is all.
    Please mark your thread as solved if things are working better.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi CharlieB23
    Welcome to NETGEAR Community!
    Please reset your router back to factory default settings. Follow the setup wizard and take note all security information for safe keeping. The links below may help out:
    How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://kb.netgear.com/31486/
    How do I set up my Orbi router and satellite?
    https://kb.netgear.com/31017/
    Blanca
    Community Team
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Be sure to use a web browser to access the RBRs web page. IE11, Firefox or Opera.
    Be sure to clear ALL browser caches before entering the RBRs web page.
    CharlieB23 wrote:
    Hi, how are you?
    Have a great day
