vegascaptain
May 29, 2017Tutor
IOS connection problem
I've had my Orbi RBK50 since January. I have had connectivity problems like the rest of you with my IOS iPad and iPhone devices. I have the latest firmware (V1.10.1.2), but the problem keeps getting worse.
No!!!, I don't want to use the Orbi as an AP with my old router, I just want it to work like it is supposed to! Netgear has not been of any help. Have they helped you???
Suggestions???
- gmjones38Aspirant
I got my Orbo a week ago to replace a set of Apple Express routers. I am experiencing the same issues with dropping connections. It got so bad, I had to reconnect one of my airport express units in order to stream from my ipad. Whenever, I would stream something it would work for a while, then the connection would drop.
I would be interested in testing the beta software if that helps solve this problem. I have a very large house 6000+ with the base and 2 satellites which all seem to have good connections with each other.
Greg
- JLG1965Guide
I am having issues with two Gen 4 Apple TVs dropping network connectivity. It started yesterday. I purchesed the ORBI system about a month ago and everything worked well until yesteraday. Did Apple or Orbi release a software upgrade yesterday that mucked things up?
- MarkkramGuide
Yes they did. Recent firmware update is a fail. iPad not connecting to rbk30 satelite. They are to advise me when a solution is available.....
- DarrenMSr. NETGEAR Moderator
Hello Markkram
We currently have a beta firmware that addresses disconnect issues if you would like to test this send me a PM with your name, email, and phone number and our support team will contact you. Also what devices are you having issues with?
DarrenM
