chuck27p
Oct 07, 2018Aspirant
Losing Wireless Connectivity
I am having a ton of issues with the Orbi router recently. I'm not technical, so having a difficult time troubleshooting. I've had it since it came out (over a year?) without a single issue, and then my new printer lost connection on my network last week, so I unplugged everything from the modem to the router to the printer. When I plugged them all back in the Orbi had a firmware update, which I completed. Now I'm losing Internet connection multiple times during the day. My daughter's chromebook seems to kill the Orbi every time she connects (is this even possible, or just a coincidence?). I have to unplug the router and plug back in and then it's back. This has been going on for days. We stream everything, so TV goes out and all devices.
I'm really unsure what to do or why this is happening. I haven't changed any settings. I also see that Backhaul Status for my satalitte is all of a sudden "poor."
Did the firmware just complete mess up my entire wifi in my house? If so, can I just go back to the old one where I wasn't having any issues?
I'm not sure what to do. I would really appreciate some help.
- ekhalilMaster
Which software did you have when you didn't have issues?
I see the same issues with the current 2.2.1.210. I also had the same issues previously on 2.1.4.16.
I also saw that a roaming device usually triggers this issue, can be your daughters Chromebook roaming from one node to another.
To recover after getting this issue, it's enough to switch off the Satellite, wait until all devices connect to the Router and stabilize then switch back on the Satellite.
- ekhalilMaster
Can't Netgear Support -somehow- help to collect logs from the router when this issue happens to be able to solve this issue?
It's a frequent issue that should be possible to route cause and solve! It just needs commitment from Netgear to fix this product!
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
