jmschnur923
Nov 28, 2017Luminary
Mixed 50 router and rbs 50 rbs 40 sats firmware
I am awating an ew orbi system which is mixed (frm Amazon). It will be the RBK 50 kit plus an RBS 40 Sat.
How do I best update an RBR 50 router and two different sat (RBS 40 and RBS 50).
Are there any issues using an RBS 40 with older firmware with an updated rbr 50?
- DarrenMSr. NETGEAR Moderator
You will want to have all units on the latest firmware you could see issues if the routers and satellites are on different firmware.
DarrenM
- jmschnur923Luminary
Since this a new install , how do I check and then update firmware as I proceed?
Can I setup with the existing firmware and then update the rbs50 and rbs40 first and then the router manually or will this happen automatically on the install.
if then what?
joel
The rbs40 and rbs 50 have different firmware. 2.074, and 2.056. Does that matter ? Or is the “latest” ok?
What firmwares did you start with ? Did you have to update the rbk firmware first including the router and then the rbs 40?
- aani75Apprentice
RBR50 and RBS50: 2.0.0.76
RBS40: 2.0.0.58
I updated both systems (RBK50 and RBK43) first before mixing them together.
- aani75Apprentice
RBR50 and RBS50: 2.0.0.76 :
https://kb.netgear.com/000049562/RBR50-RBS50-Firmware-Version-2-0-0-76-Hot-Fix
RBS40: 2.0.0.58:
https://kb.netgear.com/000049565/RBR40-RBS40-Firmware-Version-2-0-0-58-Hot-Fix
