nelsonrl
Feb 15, 2019Aspirant
Need to reboot daily.
I have had to reboot my RBR50 and RBS50 almost daily for the past few days to keep the internet reachable. Firmware is V2.2.1.210. Very straight forward config - daisy chain is off. Again, nothin...
- Feb 20, 2019
I guess I will call this one solved. I downleveled the firmware, Netgear upleveled back to what had. The system seems to be stable again.
nelsonrl
Wireless backhaul, Netgear cable modem. Orbi is setup as a router. I have about 20 devices ranging from Samsung TVs, MacBooks, ipads, YAMAHA receiver, thermostats, light switches, etc. I can log into the Rbr50 without a problem. The satellite disconnects when this happens.
Will check internet port next time it happens,
ekhalil
Feb 16, 2019Master
Thanks,
- Are you sure that the cable modem doesn’t have any router functionality?
- Which of your devices are wired to Orbi?
- nelsonrlFeb 16, 2019AspirantI am positive that the cable modem is just a modem and nothing more. Only devises hardwired are the cable modem to the RBR50 and the AV receiver to the RBS50. The AV receiver has not been powered on the last 3 or 4 times this has happened.
