nelsonrl
Feb 15, 2019Aspirant
Need to reboot daily.
I have had to reboot my RBR50 and RBS50 almost daily for the past few days to keep the internet reachable. Firmware is V2.2.1.210. Very straight forward config - daisy chain is off. Again, nothin...
- Feb 20, 2019
I guess I will call this one solved. I downleveled the firmware, Netgear upleveled back to what had. The system seems to be stable again.
Feb 16, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Try enableding Beamforming and MIMO.
IPv6
nelsonrl wrote:
I have had to reboot my RBR50 and RBS50 almost daily for the past few days to keep the internet reachable. Firmware is V2.2.1.210. Very straight forward config - daisy chain is off. Again, nothing fancy. Is this happening to others? Should I downgrade the firmware?
