nelsonrl
Feb 15, 2019Aspirant
Need to reboot daily.
I have had to reboot my RBR50 and RBS50 almost daily for the past few days to keep the internet reachable. Firmware is V2.2.1.210. Very straight forward config - daisy chain is off. Again, nothin...
- Feb 20, 2019
I guess I will call this one solved. I downleveled the firmware, Netgear upleveled back to what had. The system seems to be stable again.
nelsonrl
Feb 18, 2019Aspirant
For what it’s worth, I downleveled the firmware. The issue has cleared for the past 1 1/2 days. Not ready to declare victory just yet.
nelsonrl
Feb 20, 2019Aspirant
- Chuck_MFeb 21, 2019Mentor
There is a new version in testing right now -- it looks stable and has resolved quite a few issues, so that is something to look forward to.
- FURRYe38Feb 21, 2019Guru - Experienced User
Next time you upgrade, try do a manual FW update with web browers and PC. Factory reset the router and setup from scratch. There are other postings about how Auto Update causes problems, usually a factory reset and setup from scratch fixes this, however sometimes a manual load of FW and reset and setup from scratch gets the system to stablize. v210 has been working for others.
I would check out the beta as well:
