MarkARockport's avatar
Jun 20, 2019
NetGear, Orbi Mesh WiFi
Cannot get my Orbi to download new update via WiFi from my phone.  Have tried multiple times to download via the NetGear, Orbi App, from my phone, wait the required time and app states that it cannot download.  I do not have a second computer direct wired to the net like the instructions for a direct update.  How does one go about downloading this update?
    • CrimpOn's avatar
      CrimpOn
      Yes, do not use the Orbi app for the download.  Use a web browser to download the file and then to perform the update.
    • MarkARockport's avatar
      MarkARockport
      Downloaded the file from NetGear for the update.  My Mac will not open the *.img file that was zipped into the download.  What to do?
      • ekhalil's avatar
        ekhalil
        Master
        MarkARockport wrote:
        ......  My Mac will not open the *.img file that was zipped into the download.  What to do?
        The .img file is the file that you need to use for the update.
        1. In the web GUI go to >> ADVANCED >> Administration >> Firmware Update >> Manual Update
        2. Click on Browse and select the .img file that you previously downloaded.
  • FURRYe38's avatar
    Please use a PC and web browser to perform any FW updates. Download the FW files for the RBS and RBR. Un zip them from the zip files. Update the RBS first then the RBR.
    Don't attempt to modify any .img or .chk files. those are not user editable or modifyable. Those are used by the system.
