Celeri
Oct 12, 2018Star
New framework and wifi calling
Hello,
Since new framework, and with Circle enabled, wifi calling stopped working.
When i disable Cicle, everithing works well.
Do you have this problem (i live in France, with SFR as provider)
Thxs !
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Has a factory reset been performed and set up from scratch after the FW update?
Nothing worked ! Still no access to WiFi calls...
Reminds me to the T-Mobile Wifi calling thing - read here -> https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Circle-WiFi-Calling-T-Mobile/td-p/1638997
Any news about this problem ? For me it still does not work.
- ekhalilMaster
Celeri Can you please test the following to confirm the theory that Circle is blocking the needed FQDNs from the phone to your operator:
Can you please go to the Circle app, choose the user for which the device who have problems with wifi calling belongs to, select "Filter", then "Custom Filter", add sfr.fr and keep it as "Allowed".
