BjoernKW
Dec 23, 2020Aspirant
No Orbi RBR50 firmware update (from V2.5.2.4) available
Today, I received an email from Netgear stating that a new router firmware version is available for Orbi RBR50 routers.
However, both the iOS app and the "Firmware Update" section in the web admin panel say that currently there's no new firmware version available.
The current firmware on my router is V2.5.2.4.
- John_BaLuminaryHad the same and no update, UK
You can manually update to this version if you want to:
You don't have too. This version may not be posted to the auto update servers which isn't showing on the Orbi app or on RBRs web page.
If your system is working, you don't have to necessarily update.
Good Luck.
BjoernKW wrote:Today, I received an email from Netgear stating that a new router firmware version is available for Orbi RBR50 routers.
- Bing-StrollerLuminarySo, basically ignore the email from Netgear stating that a new router firmware version is available for Orbi RBR50 routers if yours is working OK.
Even though the Subject Line is "Important Security Firmware Update from NETGEAR"
- khemistInitiate
I had the same experience with the Android app and web admin. Contacted Netgear Customer Support yesterday. Got this response this morning:
It would be better to manually update the firmware version of the router and satellite/s,
Here's a link below to do it:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
I did a manual update to satellite and then router this morning. Everything's running fine.The two updates took a total of about 30 minutes, including testing after each update.
Glad that worked for you. Manual updates work well.
Enjoy.
khemist wrote:I had the same experience with the Android app and web admin. Contacted Netgear Customer Support yesterday. Got this response this morning:
- vajimMaster
Glad that worked for you. Manual updates are NOT recommeded by many.
Enjoy.
- --ChuckGuide
Ref: RBK Downloads (Click on "View Previous Versions) It looks like v2.5.2.4 was the last version before NG released "US Region only" versions. I guess they haven't implemented any way to indicate which region the hardware is located. Therefore the appropriate (US Region or NON US Region) firmware couldn't be listed in their app and this probably breaks any NG update pushes.
US Region got FCC'd?
v40 is the most current for ALL regions:
Only v2.7 versions are reported for US Region only.
--Chuck wrote:Ref: RBK Downloads (Click on "View Previous Versions) It looks like v2.5.2.4 was the last version before NG released "US Region only" versions. I guess they haven't implemented any way to indicate which region the hardware is located. Therefore the appropriate (US Region or NON US Region) firmware couldn't be listed in their app and this probably breaks any NG update pushes.
- --ChuckGuide
While v40 could be used for any region.
At the current time, v2.7.1.60 is listed as the current version for the US region.
FURRYe38 wrote:v40 is the most current for ALL regions:
