Doug-48051's avatar
Doug-48051
Luminary
Jul 16, 2017
Orbi AC3000 - Amazon Dash Wand does not see 2.4Ghz network
I have an Orbi AC3000 on FW1.12.0.18. Everything appears stable, with one small issue. Today we purchased an Amazon Dash Wand. This is a small mic device that functions with Amazon Alexa.
The wand operates only on a 2.4 Ghz frequency.  The wand is not seeing the Orbi SSID?  I can’t confirm if this is due to a single SSID for both 2.4 and 5 Ghz network.
The Wand App never gets to the network authentication screen with Network Name and Password.
Is there a method to confirm the problem and correct the issue?
  • Issue Resolved
    The first time I tried to connect the Amazon Dash Wand
    the Orbi Access Control was set to NOT ALLOW New Devices.
    The Orbi automatically added the wand to a reject list.
    So on my second connect attempt
    I opened the Access Control from the Web UI. BUT the Wand was still listed on the reject under a random device name. WNC-00-00
    Once I opened the Access to add New Devices AND Removed the wand device from the device reject list the Amazon Wand was able to connect to the orbi without any issues.
  • I can't spaek to the Wand itself, but I can confirm that I have a few 2.4-only devices (Leeo, printer, Kindle, and an older Amazon Fire tablet) that have all always connected fine and without any hoop-jumping to my Orbi (including this latest Orbi f/w).
    Good luck - I hope it works out eventually!
    • Doug-48051's avatar
      Doug-48051
      Luminary
      Issue Resolved
    • rhester72's avatar
      rhester72
      Virtuoso
      My wand connected to and was/is working fine on both of the last public firmware releases, FWIW.
      Rodney
