mljones6
Apr 03, 2018Aspirant
Orbi and Lennox iComfort thermostat
I've just had a new Lennox iComfort thermostat installed, and it will not connect to Orbi. The thermostat will connect to my iPhone hotspot, but not Orbi. The thermostat shows a good WiFi signal from Orbi--3 or 4 bars. Anyone had a similar problem, and how did you troubleshoot it?
What model Orbi system do you have?
What FW version is loaded?
Try setting a temporary OPEN on the Orbi router and see if the device will connect. Then set WPA and TPIK and see if the device will connect. Then try WPA2 and AES only. Any of these connect?
Disable Beamforming, MIMO, Daisy Chain and Fast Roaming and test.
I would check with the device Mfr help and info regarding this. See if they have any known issues with NGs Orbi systems.
- nbuubuGuide
I have the same setup, with the Lennox iComfort, and ever since the latest forced Orbi firmware it won't connect at all. I reset the wifi password to be super simple with no special characters after reading the iComfort has issues with those, and it connected once for about an hour last night before failing to connect again all day today.
For me this is a fairly recent thing, coinciding with the newest firmware. I think it broke something.
- tsigLuminary
wonder if it could be a 2.4ghz channel issue.
- Retired_Member
- Retired_Member
how do you perform the setup? At the Lennox iComfort thermostat or using your Iphone?
- nbuubuGuide
I do the wifi setup right at the iComfort panel.
I upgraded the firmware to the latest 2.1.4.14 and it connected once for about 30 minutes, but then disconnected again. And again, it's showing 3 identical SSIDs being broadcast.
The iComfort panel just sits at "joining" until displaying an error, wifi command timed out. This problem is new to me, and it's only been since 2.1.4.10/14 releases.
- tsigLuminary
can you forget all of the previous networks and start over? Weird that you can see three different networks, can you see them on all devices?
- thermo1Aspirant
I too have had a connectivity problem as described. My thermostat was working fine and installed on 5/16 until late summer of 2018. In June of 2018 I installed my Orbi system without a problem, including my thermostat and all other wifi devices. In September, my Orbi connection to my Lennox icomfort thermostat became intermittent and then virtually noexistant. I disconnected Orbi and reconnected to my former router and the thermostat connects to the wifi as it should. I have many deadspots in my home that Orbi corrected, but the thermostat connection is unacceptable. Help!
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try this as well:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
- sc13Tutor
I just got our system installed which includes Lennox iComfort S30 smart hub. They will not connect, and yes it shows WPA connection attempt.
- sc13Tutor
I just solved this problem by going back one version of firmware in my Orbi.
for me, this is where I was able to get a previous version
https://www.netgear.com/support/product/RBR20.aspx#download
then I logged into my system
Advanced > Administration > Firmware Update
Then click Browse, and search for the firmware file that you downloaded
Make sure that you select the device then click Update
Thanks for letting us know...
- sc13Tutor
Back to the drawing board. Going back one version worked until the auto update [which can't be changed] changed it back to the latest version. I was on the phone with Netgear for awhile, but still haven't resolved the issue. Same situation here, no problem connection the thermostat to my iphone.
- TexbruInitiate
Chatted with NetGear and my Lennox icomfort s30 connected fine to netgear orbi guest network...so all is working fine...
hope new version has a fix
