MightyChadster
Aug 02, 2018Aspirant
Orbi and N300
Have an older N300 modem/router. Having trouble setting up new Orbi RBK40 system. Not technologically genius material here :-).
What is the actual mfr and model# of this ISP modem/router?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.- MightyChadsterAspirantThe modem is Netgear N300
Whats the model number say on the label sticker under the modem?
- MightyChadsterAspirantNetgear24 ?
Cvna you go here and review the link on the right side of this page to help you idenfiy the model# of the modem?
https://www.netgear.com/support/
Modem Combo Units:
Couple of options,
Ok, so you'll need to remove the WNR2000 router from the wall outlet and replace it with the Orbi router. Connect the wall outlet to the Orbi router and use a wire connected PC and a web browser and navigate to orbilogin.com or 192.168.1.1 and walk thru the setup wizard.
