dainamuc's avatar
Jun 01, 2019
Orbi keeps disconnecting
My Orbi keeps disconnecting and purple light appears. I try to reconnect it but it takes at least 4 attemps before it connects again. Or it will sometimes connect back by itself. The issue happens many times a day, internet is completely unreliable. Any ideas on what could be done to fix it?
  • Same problem. I also saw this posted on reddit.com/r/orbi with several comments of people having the same problem. A few claimed that disabling armor helped. I don’t even know what armor is. This kit was too expensive for this nonsense
    • dainamuc's avatar
      dainamuc
      Tutor
      I agree. And on top of it all they offer 90 days free assistance and all the issues started just after that. That is not right.
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    Which unit displays the purple LED on top? The RBR or RBS?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    What WPA security modes are you using?
    Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
    • honyin's avatar
      honyin
      Hi,
      I've been suffering this same issue.
      It seems to have become a regular occurrence since upgrading the firmware to V2.3.1.60.
      I have since manually downgraded the firmware to the previous V2.2.1.212.
      Hopefully that will help.
      I'll keep you posted.
      Steff
      • ekhalil's avatar
        ekhalil
        Master
        This is an issue that I also saw in the latest software updates (since 2.3.1.28).
        I fixed my issue by reducing the DHCP lease time as follows:
        * From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
        * Enter admin as user name and your router’s management password
        * Tick "Enable Telnet" option
        * Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
        * Enter the following commands:
               * root@RBR50:/# config get wan_lease    —> Should give you 86400
               * root@RBR50:/# config set wan_lease=750
               * root@RBR50:/# config commit
        Christian_R
