netmaster2020's avatar
Oct 01, 2017
Orbi randomly dropping internet connection despite V2.0.0.74 update
Hi all,
I recently purchased an RBK50 Orbi + satellite router but it is dropping internet connection randomly despite updating firmware to the latest V2.0.0.74.  This is more often the case upon waking up in the morning.
Any suggestions?
  • The new firmware did not resolve the problem for me.  There's a new version which released today (.18) that is installing now.  I'm not overly hopeful.
  • Hopefully adding info to the ongoing troubleshooting...
    I have an ORBI RBR50 and satellite.  I was happy to see the issue is apparently caused by the Google cast feature, but was dismayed because I don't have any android or google cast devices in my house - at least that was what I thought.  We have all Apple products, which has their own cast-like version called Air Play.  I thought that perhaps that may be included in the issue (and it may be) - but then realized my Vizio TV has something called Smartcast.  I checked the web and see that Smartcast uses Google Cast technology.
    So... if you are confused that you are experiencing this issue like I was, and don't have any android or google devices - you may still be impacted if you have Vizio TVs in the house.
    I have just installed the new firmware version, which they have made available to install through the web admin client.  It was a painless, automatic, upgrade.  I am now waiting to see if that resolves the issue.
    • dismoreb's avatar
      dismoreb
      Well.... after about an hour after the latest firmware update (2.1.2.18), my wifi just dropped.  I would note, my satellite firmware is still set to v2.1.1.16, but when I looked for an upgrade for the satellite none appeared available to me.
      So - looks like Netgear needs to keep after a fix.
      • pfworks's avatar
        pfworks
        Guide
        I would try updating satellite manually. All my problems appear to be with my satellite, so for me, that's the important one.
  • Google is supposed to release an update for their products that should roll out tomorrow supposedly to fix this.
    • sleepr88's avatar
      sleepr88
      Apprentice
      How long for a Chromecast/Android fix Netgear? TP-link, Linksys, and others have already gotten it fixed
      • dneumannjr's avatar
        dneumannjr
        Tutor
        Any update here? I am on firmware 2.1.2.18 and have rebooted/dropped multiple times today. Getting very annoying and debating on returning this system. But considering this does not seem to be all on Netgear I was hoping something else was being done.
  •  Step 1 update your firmware
    Step 2 reset to factory default
    Step 3 configure again your router. Let defaults options. Is the best solution and always is working.
    You don't need to enable beamforming or mu-mimo.
    • POSEIDON7902's avatar
      POSEIDON7902
      Apprentice
      If you have any Android phones, update play services. If the full release isn't available, follow the guide I posted to download the beta. It fixed the problem for myself and several others I know as well as being documented to fix other manufacturers as well. Do that before you do anything else. Then if you still have a problem try other methods.
        dneumannjr
        Tutor
        Poseidon,
        Can you verify what playstore version is running for you that works? I am currently on 8.5.46.W-all but have not turned my wireless back on. Have had no issues since I turned my wireless off on the phone. I also signed up for BETA but have not recevied a notification that an install has occured. Thanks for your help.
  • Orbi keeps on dropping the network multiple times a day and sometime multiple times every hour. It comes back online if I turn off and turn back on.. modem works perfectly fine.. help...
