trickylad's avatar
trickylad
Orbi RBK40 extending to garden room
Hi all.  First post so thanks in advance for the help.
I have had a Orbi RBK40 mesh for a few years.  It's been brilliant.
Like many others we're building a garden room and looking to get it connected.
It's going to be about 60ft from the main house.  The router in the house is at the front.
The garden room company have asked to have power and ethernet supplied to the pod underground.  We're having some work done in the garden so that's not an issue.
My assumption is that all i need to do is buy an RBS50 satellite (better reccommendations welcome) and simply connect this to the ethernet connection in the garden room.  I'll then be able to connect devices in the room via wifi using the same network as the main house.  The other end of the ethernet connection will just link to the Orbi router inside.
1) Checking i've got the right plan.
2) Are there any recommendations for the type of cable we should use (Cat 6 i've heard is best and gel filled to protect it underground)
3) Am i coming at this the right way?  Would a point to point set up be easier/more reliable/better?  If so, any pointers here would be brilliant
Thanks all
RH
    Thanks all
    RH
    An RBS50 satellite would be a good choice to extend out to the garden room. You have other choices as well, if available
    Regarding running cable, cat6 is a good choice. If you are going to bury it, either use burial grade cable or run it in pvc pipe to make it last longer.
  • I forgot to mention you can also use WIFI CPE to get WIFI to the garden room wirelessly. And possibly powerline adapters would work to get network capabilities there.
    Either one you can plug the satellite into them and have your wireless mesh system extended to the garden room.
  • CrimpOn's avatar
    CrimpOn
    The construstion company is making a good recommendation.  Electrical supply is obvious (duh) and they are smart to recognize that in 2020 a customer will need ethernet (Cat6 suitable for underground burial in a PVC conduit).  The conduit is (a) to protect the cable and (b) to allow you to pull it out and replace it later without digging up the property. Dropping in a 1" PVC conduit for data is a trivial expense compared to the electical.
