ZoneMaster's avatar
ZoneMaster
Apprentice
Apr 29, 2018
ORBI RBK53 (AC3000) "No AirPrint Printers Found" After Firmware V2.1.4.10 Installed
Have been running my ORBI RBK53 system for almost a year. AirPrint from multiple iOS devices (1x iOS 9.3.5 & 3x iOS 11.3.1) worked flawlessly until a few days ago. The only thing that changed was the ORBI firmware, which is now at V2.1.4.10. Wi-Fi printing from iMac & Windows is still working but my two AirPrint printers (one HP & one Brother) are reported as "No AirPrint Printers Found".
I have performed the following troubleshooting:
  1. Verified printer settings are unchanged
  2. Performed network port scans
  3. Rebooted ORBI network & printers numerous times
  4. Factory reset of the OBRI units
I have observed the following:
  1. There is NO discovery of AirPrint printers
  2. I can still print via AirPrint if a printer was still listed as a previous printer
  3. Rebooting printer may reenable AirPrint for a very short time
  4. The network scan shows no Bonjour/Zeroconf services
It appears the latest ORBI firmware is suppressing AirPort discovery.
  • I have been running the 2.1.4.10 firmware since last week. Network scan via "Net Analyser" iOS app showed NO Bonjour flags present
    I have performed the following additional toubleshooting from my iMac (which is fairly distant from my Comcast/ORBI gateways):
    1. Connect ONLY via my Comcast Wifi Modem:
      1. Powered off ALL ORBI units:
      2. Turned on WiFi on my Comcast Router
      3. Logged in to my Comcast WiFi
      4. Weak signal & slow upload/download speeds
      5. mDNS/Bonjour/AirPrint was rock solid
      6. Network scan via "Net Analyser" iOS app shows Bonjour flags are present
    2. Connect ONLY via ORBI RBK53:
      1. Turned off WiFi on my Comcast Router
      2. Powered on ORBI RBR50 Router
        1. Logged into ORBI WiFi
        2. Better signal & faster (but not max) upload/download speeds
        3. mDNS/Bonjour/AirPrint working. Network scan via "Net Analyser" iOS app shows:
          1. macOS & iOS seem to reliantly report Bonjour as present
          2. AirPrint printers (HP & Brother) sometimes don't report Bonjour as present
        4. Waited
      3. Powered on ORBI RBS50 Satelite closest to my iMac
        1. Max signal & max upload/download speeds
        2. mDNS/Bonjour/AirPrint working
        3. Waited
      4. Powered on final ORBI RBS50 Satelite
        1. Everything working
        2. Waited
    While mDNS/Bonjour/AirPrint is still sometimes glitchy. It is working under the 2.1.4.10 firmware after starting the router & satellites in slow sequence.
        4. Waited
        3. Waited
        2. Waited
    • altern8's avatar
      altern8
      i have a rbk20 and this issue popped up after upgrade from 2.0 to 2.1.4.10.  I ended up disabling MUMO, Fast Roaming and Beam Forming to fix the AirPrint issue.  I don't know if all or just one option is the cause but I have no patience at this time to further troubleshoot.
      • ZoneMaster's avatar
        ZoneMaster
        Apprentice
        BTW: NG's "90 day & then you pay" support is terrible! Heck, Apple (which so many love to compain about) still lets you contact them after 90 days & has a knowledge base for questions & error reports. NG has a paywall & community support!
  • FURRYe38's avatar
    Something you might want to contact NG support about and ask for help with. Might need to revert to prior working FW.
      • FURRYe38's avatar
        Try Chat or try one of the forum moderators here in the forums.
  • FURRYe38's avatar
    What FW version was it working on?
    Try a factory reset and set up from scratch.
      ZoneMaster
      Apprentice
      Don't know firmware version prior to update, only that I have never had problems before afew days ago. I have rebooted ORBIs numerous times & performed factory resets/new system config at least 3x.
