RikParr73
Oct 12, 2018Aspirant
Orbi RBR50 - Poor Ethernet Backhaul on Satellites
Hi
I have RBR50 and 2 x Satellites. I also have Virgin Media Superhub 3, set in 'Modem mode'. Modem is on static 192.168.0.1 (Unable to change ISP set)
Satellites are connect via ethernet. Backhauls come from connections connected via my Cisco SG200-50P Poe Switch, the Virgin superhub in modem mode is connected directly to the RBR50 as normal. RBR50 is connected directly to the Cisco PoE in the loft.
I am having intermittent loss of connectivity on the sats, or poor wi-fi signal (Sats go amber) Sat 1 is located dapprox 30ft from RBR50 on ground floor. Sat 2 is located approx 40ft from RBR50 on first floor.
I have not done any fancy set up on the Cisco PoE, just plugged everything in. Can anyone advise any fsult finding I can do to trace the issue please?
I have approx 50 devices wired/wireless on the network. Down speed is usually 180mbps.
Thanks in advance.
Regards
Rik
If this is your switch your using, I believe this maybe a managed switch:
https://www.cisco.com/c/en/us/support/switches/sg200-50p-50-port-gigabit-poe-smart-switch/model.html
if so, see if you can find the IGMP proctols with in it's management page. Disable ALL IGMP procols on the switch. Others have reported having problems with Orbi systems and Managed switches. Seem that IGMP protocols maybe the culprit:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123I use non managed switches and have had not problems connecting my satellite via wired back haul.
- ekhalilMaster
What wired devices do you have connected to the router/satellites?
Please check this https://community.netgear.com/t5/Orbi/quot-Wifi-Disconnection-quot-issues-are-still-in-2-2-1-210/m-p/1648667#M42790
