AdamGar
Nov 17, 2018Aspirant
Orbi RBR50 404 Not Found
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.
- ekhalilMaster
AdamGar wrote:
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.This can happen if you have multiple IP networks.
Is your Orbi configured as Router- or AP Mode?
If in Router Mode, is your ISP router bridged or is it also functioning as router?
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?FYI, Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router
AdamGar wrote:
My Frintier wireless router is connected to my Orbi via ethernet. If I connect directly to my router Wi-Fi I have no issues. If I connect to Orbi some websites give me a 404 page not found error.- AdamGarAspirantThanks. I’ll give this a try.
Let us know how it goes...
I have the same problem as mentioned above but I am a bit tech naiive and I do not know how to check the things you have suggested.
Regards
Kerry
- ekhalilMasterA simple and quick way to test if you have double NAT is using traceroute.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8
Look at the result printout, If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. :)
Private IP addresses are usually something like 192.168.x.x or 10.x.x.x.
