RJA1971's avatar
RJA1971
Orbi RBR50 Firmware V2.2.1.210
Stupidly, I updated my firmware yesterday, from a rock solid system to what seems to be, a less effective network: V2.1.4.16 to V2.2.2.210.
My issues is that signal stregnth is reported to be variable and always, lower than previously, between my PLUG-IN and router, and my SATELLITE and router.
I have backdated the firmware several times, but within moments both the ROUTER and the PLUG-IN update themselves back to the new firmware. The Satellite (RBS50) won't backdate at all.
Any ideas?
  • FURRYe38's avatar
    Factory reset the router and satellite and set up from scratch. Others have mentioned doing this resolved problems for them.
    • RJA1971's avatar
      RJA1971
      Thanks, I'll try it. I've reset the Plug In and router, but not the Satellite.
      I'll try again tomorrow and let you know.
      Thanks.
      R
      • LarryinNJ's avatar
        LarryinNJ
        Star
        I’m doing nothing, and hoping for the best. The 2.1.4.16 firmware was as good as I could ask for and would stay on it forever, if I could.
        But I can’t...
  • After this upgrade, my download speed of any device connected using ethernet has drop. I am a 1G AT&T user and now if I am connected behind the AT&T router, everything is around 930Mbps download speed. If I go behind the Orbi, average is around 540Mbps. Something changes in this upgrade.... Any idea of what can be happening.
    AT&T modem is in Passthrough mode...
    Did a factory reset already! - This fix the costaly droping the wifi or internet connecting and had to refresh it...
    PD: The idea of just 30days support is ridiculous...Netgear have to give better support here.... Especially when they put buggy firmware...
