drlopezmd's avatar
drlopezmd
Orbi RBR50 shows offline, but has Internet access
connected into modem and disconnected the separate spectrum wifi tower/router.  have internet access.  succesfully added two satellites.  app says "internet:offline" .  Does this matter?  Does it affect my wifi speed?  I have 400 mbps down from the cable company but effectively only 130 due to configuration of my house, i believe, but i wonder if fixing the "offline" issue will help.
  • plemans's avatar
    What modem is this?
    ISP installed devices tend to be combo devices which put you in a double nat. Orbi frequently shows offline even when its online when its in a double nat situation.
    https://kb.netgear.com/30186/What-is-Double-NAT
    • drlopezmd's avatar
      drlopezmd
      thank you--Iwill contact spectrum to ask about that and will let you if it worked.  The modem just says "Spectrum".  Will find out
      drlopezmd
      It’s a UBEE modem only. No wifi or router capability.
      • FURRYe38's avatar
        Ok, you fine here then.
        What does the status say on the RBRs web page under Basic Tab using a web browser and a PC?
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • Log in in your computer and fix your time zone in NTP setting it looks like that is the the problem
