IGY
Dec 03, 2017Aspirant
Disabled network interface (Eth1) after firmware 6.9.1 on RN212
After upgrade to 6.9.1 on the the ethernet adapter appears disabled.
They were bonded prior to upgrade. Deleted the bond, but eth1 appears disabled.
Also cannot re-bond again.
Went back to 6.9.0, but the same. Upgraded to 6.9.1 and no change.
Need to enable back the second adapter.
Maybe try an OS reinstall from the boot menu?
- IGYAspirant
Managed to activate it by un pluging the main Eth0 cable, restart NAS on Eth1 only and then once active plugged second cable as well.
Also successfully created NIC Team (Bond).
So fixed! Was just about to do the OS reinstall as well but not necessary now. :)
