batpot's avatar
batpot
Tutor
May 18, 2019
Orbi says zero satellites connected... But have Ethernet
Bought a package with the rbr20 router and 2 satellites.
The satellites are connected to Ethernet as well, so it is doubly confusing why it can't see them.
None of the units have lights on, which is usually a good sign.
What is going on?
  • Have you synced the Satellites with the Router?
    Syncing is done by pressing the Sync button on the Satellite and on the Router and waiting few minutes until the top ring LED on the Satellite turns blue.
    • batpot's avatar
      batpot
      Tutor
      Yes, and the lights pulsed white for a while, and then extinguished again.
      • batpot's avatar
        batpot
        Tutor
        And I can connect to the satellites, and the internet works, but when I try to open the app, it says problems connecting to network.
  • That shows 2 satellites connected via 5 GHz, and good back haul.
    • ekhalil's avatar
      ekhalil
      Master
      Good, then there is no issue with the Satellites.
      Please describe your issue with the app.
      • batpot's avatar
        batpot
        Tutor
        The app says zero satellites connected, and when I try to bring up the app while connected to one of the satellites, it faults and says no wifi.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi batpot
    May I request for the following information\
    - Router and satellite firmware version
    - App version? Is it an Android or iOS?
    - Have you tried to uninstall and reinstall the app?
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi batpot
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      Blanca
      Community Team
    • batpot's avatar
      batpot
      Tutor
      Did a fresh install, which turned into a real PITA, because even after deleting the satellites, and factory resetting them, they would never be found by the app.
      Had to also factory reset the router. After resetting router into AP mode, same issue - logging into the router via web interface shows 2 satellites, but app still shows zero.
      Firmware is V2.3.5.26 on all devices. App version is Android 2.3.7.622.
      • Blanca_O's avatar
        Blanca_O
        Hi batpot
        I have sent you a message. Please check your inbox.
        Blanca
        Community Team
