Hamstar
Jun 22, 2018Guide
ORBI slow upload after 2.4.1.16 firmware update
I am a new ORBI home user. I installed my ORBI system on 6/9/18 on AT&T -verse 1000. It was setup in ROUTER mode by default. My download/upload speeds were pretty good -- about 600-800
I swi...
dmhayes007
Sep 28, 2018Tutor
Same boat. After most recent firmware update, the ORBI is essentially unusable. Latency is super high, download/upload speeds terrible and very sporadic. I can turn ORBI off and plug in my old Nighthawk and get normal speeds. I can even just turn on the wifi of the crappy modem my ISP gave me and speeds are normal. Use the ORBI and internet is miserable. Had been very pleased with ORBI but it's turned off right now as it is unusable due to this crappy firmware upgrade.
Sep 28, 2018Guru - Experienced User
Ask to try the beta here:
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you just updated FW, please do a factory reset on the router and satellite(s) and set up from scratch. Others reported having this issue until the reset was done then all was good after that.
https://community.netgear.com/t5/Orbi/RBK40-Download-Speed-Slows-Down-After-5-Days/m-p/1643475/highlight/true#M41776
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1548414/highlight/true#M27868
https://community.netgear.com/t5/Orbi/speed-slows-down-Orbi/m-p/1551822/highlight/true#M28289
https://community.netgear.com/t5/Orbi/Is-2-1-3-4-in-auto-update/m-p/1553979/highlight/true#M28616
https://community.netgear.com/t5/Orbi/Orbi-Satellite-RBS50-Not-Connecting-via-Ethernet/m-p/1556692/highlight/false#M28949
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- dmhayes007Sep 28, 2018Tutor
I manually downloaded previous version of FW I was on (i think 2 versions back) and things are perfect again. The number of folks that seem to be complaining about this tells me it is bad FW and should be pulled. Also, I don't plan on going through the hour long 'from scratch' setup. I'll stay on this FW until Netgear releases a stable update.
- FURRYe38Sep 28, 2018Guru - Experienced User
Good Luck.
Even when NG releases another FW update, you'll need to do another factory reset and set up from scratch if you seem to experience continued problems.
