Mts362
May 21, 2019Aspirant
Password continually needed
Orbi based network requires my password be entered on my phone 1-2 times each day. Pretty frustrating.
Password to what? Most devices these days "remember" the password to every WiFi network they have been connected to. If your phone is not remembering the WiFi password, something is wrong with the phone. (I have gone to visit relatives, and after six months away my phone logs in as soon as I walk in the door.)
If you are referring to the password to the Orbi administrative account, that's a different matter. I, personally, have not left the Orbi app open on my phone or tablet long enough to notice.
- Mts362AspirantYes, I’m familiar with how these passwords are usually remembered. That’s why I’m asking. My phone will remember dozens of network passwords but not my Orbi one that was just installed a week ago. Thanks for responding though.
Mts362 wrote:
My phone will remember dozens of network passwords but not my Orbi one that was just installed a week ago.Have you been in to check the saved wifi passwords on your phone?
It may be remembering an old password. Tell the phone to forget that and it may remember the new one.
As CrimpOn says it is really down to the phone to handle things like that. The router just puffs out wifi. What things do with it is in their hands.
Is the Orbi system operating in Router or AP mode?Have never seen this my self or others haven't posted about it...
- Mts362Aspirant
Firmware on main router is V2.3.1.60. Operating a single (wired) satellite with same firmware. Connected to a TP-LINK TC-7610 modem. Both router and access point show up as "green" in the Orbi app. The problem does not appear to be happening with other devices like my laptop....so I get that it is largely a device issue. But at the same time, the phone has never had this issue with any other (of probably ~50 over the last 2 years) wifi networks. So maybe there is a specific interaction issue at play. Thanks!
IF other wifi devices do not exhibit this issue and the problem is only with the phone then possbible that something on the phone and recently taken a bad turn.
Have you forgotten the current wireless profile, powered OFF the phone and back on and then re-entered the SSID and PW?
AFter updating to v60, was this updated and continued or has a factory reset and setup from scratch been performed?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Mts362 wrote:
Orbi based network requires my password be entered on my phone 1-2 times each day. Pretty frustrating.1-2 times a day is going to be difficult to diagnose. I can think of some suggestions, but they are not really practical:
- Does this happen with any other network, such as at work? Alas, "no problem" might simply mean, "haven't been connected to this network long enough."
- Does it happen if the phone is in "safe mode." A frequent suggestion when phones act up is that a recent app install or update has affected the phone, and running in safe mode disabled user apps. This is also impractical because (a) we depend on our apps, and (b) even running "all day" might still be a false positive. Many years ago I had an Android phone that would go whack-o, and the only cure was to do a factory reset and reload applications. What a pain!
- Go back to the old WiFi. If the Orbi was just installed a week ago, is the old WiFi still available? Swap them and see what happens.
- Pose the question in the phone user forum.
- Are there other smartphones that have (or don't have) this issue?
- Is there anything in the Orbi logs?
- Does this phone have an assigned IP address? My internet search turned up instances of phones losing WiFi because another device on the network showed up with the same IP. Obviously an error, but some things may not be active on the network all the time. (Thermostats, for one)
- surgio98Initiate
On Android there is an App Cache and App Data. Cache is like the memory being used currently in the app and Data is like the long term storage the app uses. I would do the following.
Us my user name and password from another device to make sure it's correct. Then wipe App Cache and App Data. Restart Phone and then login.
- surgio98Initiate
Cont'd Deleting apps do not always remove their app data (Not sure about Cache). So even if you deleted and re-installed the app I would follow the aforementioned steps.
