dano17's avatar
dano17
Tutor
Feb 23, 2020
Problem after Orbi RBR50 firmware update to 2.5.1.8
I recently update the firmware to 2.5.1.8 and have had nothing but problems getting all devices working properly again.  The reason that I updated was that devices were disappearing from the Orbi app as not being attached, but they were indeed attached and mostly working normally.  I was hoping the firmware update would correct the issue, but it not much different (ie, some are still disappearing after a Orbi reboot).  My biggest problem now has to do with an old IP address orginally assigned to my Pentair pool control adapter.  During the original Orbi installation, the subnet mask IP range was 172.16.0.x.  Not sure why it chose this range, but I went with the default.  During the recent firmware update to 2.5.1.8, the subnet mask IP range was changed to the typical 192.168.1.x.  As far as I can tell, all of the devices except for the Pentair adapter updated, while the Pentair adapter kept an IP address of 172.16.0.9.  Now I cannot communicate with the Pentair system, and I've tried resettting the adapter, powering down the adapter and the Pentair controller in every conceivable order.  Looking for advice to correct the issue, other than starting all over again as a new install, which is a several hour ordeal (like most people, I have a lot of devices).  I've attached a screen snippet for reference.  Thanks.
  • dano17's avatar
    dano17
    Feb 28, 2020
    Thanks again to all who responded to my posts.  I was able to isolate the issue to the Pentair protocol adapter not releasing it's old IP address by reverting back to my older Netgear WNDR3700, where it displayed the same bad IP address.  A tech support call to Pentair provided some critical undocumented steps to reset the protocol adapter (the reset button on the adapter must be pushed 3 times within 2 seconds).  The adapter then released the old IP address and accepted a new one assigned by the router.  I also regressed back to the RBR50 / RBS50 V2.3.5.30 firmware to address the buggy 2.5.1.8 firmware whereby the devices (including the satellite) disappear over time rather than showing as attached devices.  I'm back up and running now.  I'm disappointed in the Orbi firmware, as there has been something wrong with each version that prevented it from operating as advertised.  The stuck IP address, however, was a Pentair documentation issue, compounded by the Orbi firmware update.  Thanks again for the assistance, and hope my post can help someone else in the future.
  • FURRYe38's avatar
    "the subnet mask IP range was 172.16.0.x." This is not a subnet mask, more like the WAN IP address. A private IP address and not a public IP address.
    There a built in router at the modem by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • CrimpOn's avatar
    CrimpOn
    The solution is to set up the Pentair controller from scratch so that it gets a correct IP address.  I'm happy to look at the Pentair setup instructions if you supply the exact model number and the user manual is on the web.
    One thing you might try is to go into the Orbi web interface, Advanced Tab, LAN Setup, and assign a specific IP address to the Pentair using the MAC address shown on the Attached Devices display.  Then, power off the Pantair and power it back on.  If it is asking the Orbi for an IP address using DHCP, it might get the new one.  If the Pentair has been set up with a "static IP", then the only way to get it changed is through a fresh setup.
  • The easiest solution here is to just change the LAN up address range on the Orbi back to 172.16.0.x.
  • Thank you for the quick post advice.  Unfortunately, I see no way to change the IP address per your advice "go into the Orbi web interface, Advanced Tab, LAN Setup, and assign a specific IP address to the Pentair using the MAC address shown on the Attached Devices display".  I have tried to block the device, as well as reserve it's IP address to a 192.168.1.XXX address, but the old 172.16.0.9 IP address remains no matter what I do.  This seems like a bug to me.  Your advice seems routine for other routers (my previous router was a an older Netgear, which I used this feature on occasion).  So, even when I try to reserve a proper address, the router ignores my input and maintains the old invalid IP address for this one device.
    I have already performed a factory reset on the Orbi, and the old IP address, for some reason, is stuck on the Pentair adapter MAC.  Never seen this happen before, and running out of ideas.  Out of curiosity, does the satellite possibly maintain a copy of the old IP address?  When I performed a factory reset of the router, the satellite was probably still powered up.  Like I said, I'm running out of ideas.  Thanks...
    • CrimpOn's avatar
      CrimpOn
      That is certainly easy to test.  Power off ALL of the Orbis.  (Not "reset", simply power off.)  Then restart them.  The satellite should remember *nothing*.
      Still looking for the model number of that Pentair controller/adapter to see how to set it up from scratch.
    • eljarviso's avatar
      eljarviso
      Luminary
      You should be able to change the settings on the web interface in advanced -> setup -> LAN setup. You should be able to change the routers LAN IP which should change the subnet dhcp uses. Unfortunately I’m running my setup in AP mode so this section is greyed out and I can’t get into it to see exactly what settings need to be changed.
    • FURRYe38's avatar
      I would factory reset the RBR. I would also factory reset the CM1100 as well. Set both up from scratch. Ensure LAG is disabled on the CM1100. Walk thru the setup wizard with a wired PC and web browser. You should be acessing the RBRs web page at 192.168.1.1 here.
      Use a different web broswer when walking thru the setup wizard. I use IE11, Firefox or Opera. Opera most of the time.
      I have this same setup and modem and FW version. I actually have two Orbisystems conencted to the one CM1100. RBK50 and RBK853. Both get different WAN IP addresses on the WAN side. The RBK50 I set for 192.168.0.1 and the 850 system I set for 192.168.1.1 on the LAN sides.
      • dano17's avatar
        dano17
        Tutor
  • Thanks for your post.  The modem is not a router also.  It is a Netgear CM1100.
