dominicchengct
Apr 12, 2020Aspirant
RBK20 disconnect when copying many files
I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks
Dominic
Be sure to make a backup configuration to file for safe keeping. Helps save time if a reset is needed.
Please mark your post as solved so others will know.
Enjoy. :smileywink:
dominicchengct wrote:I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time.
This is an interesting situation.
- How are the NAS connected to Orbi?
Both to the router?
Combination of router and satellite?
Wired, WiFi, or a combination? - What is the meaning of "disconnect"?
The NAS device transfers fail?
Other devices lose internet connection?
Thanks
- dominicchengctAspirantHow are the NAS connected to Orbi?
Both to the router?
Both to the satellite. If connect to router, router disconect at once.
Yes
Both r wired.
All devices connected to the wifi went disconnected. No more signal.
I think it is due to wifi lost. It transfers awhile then fails
Yes, as mentioned above
dominicchengct wrote:I bought the router days ago. I connected two NAS to it. When i try to copy a large amount of files from one to another. The router disconnect from time to time. Can anyone help? Many thanks
Dominic
Hi there, i follow your suggestions. And then try copy 3gb and 2gb from one nas to another. Both ok now. Will keep try more. Thanks a lot for yr support amd you really save me from a lot of trouble. Have a good day.- FURRYe38Guru - Experienced User
Enjoy. :smileywink:
