MobyDev
Aug 04, 2019Aspirant
RBK50 causing my CM1000 to power cycle
I have a Netgear CM1000 modem that’s been working fine connected to a Google WiFi system for over a year. I got the Orbi RBK50 system installed and it would cause my CM1000 to power cycle continuously. I hooked up my Google WiFi system back up and it’s working fine. Any suggestions?
My solution was to move them about a foot apart and that seemed to work keeping the home phone connect from rebooting over again and again.this worked until I moved the satellite that room.
Continuously as in all the lights go off, it restarts by itself, and as soon as all the lights come on, it goes back off again? over and over? There is never a chance to connect to the internet?
- techmoby43Aspirant
Excellent. I got it packaged up to return tomorrow, but I think I will try this out before I do that . Thank you!
There should be at least 3 feet or more between the modem and any wifi router. They should never be in close proximity.
Tjharris6 wrote:My solution was to move them about a foot apart and that seemed to work keeping the home phone connect from rebooting over again and again.this worked until I moved the satellite that room.
"Never" is such an absolute. My Orbi has been about one foot from two different modems for nearly three years and has never caused a problem. I would think that modem manufacturers should expect customers might place these items close together for convenience and shield the modem to prevent interference. "Good practice", absolutely. "never" seems a bit much.
