colinson's avatar
Mar 13, 2020
RBR20 Slow Wifi
This post is nothing new, plenty of similiar ones on the board.
I've got 500/50 cable to curb. It's an Arris modem, DG3450A.
I've got an RBR20 and three satelites. One is daisy chained. They're all on 2.3.5.26. Some are more than 30 feet away.
The house is large at about 3000 sq feet and part of it is old and a lot of thick plaster walls. Its a western city neighborhood with reasonable sized lots. I can see some others wifi sometimes but its not like I'm in a condo.
The Orbi router is plugged right in to the modem and on the wired speed test I get 400 something / 40 something. There's a NAS wired in to the Orbi and it too gets those speeds.
Wifi has always sucked but it seems worse recently. Sitting 2 feet from the RBR20 it almost never places a device on 5 Ghz. Android phone, android tablet, macbook pro, chromecast ultra, doesn't matter. Almost always on 2.4. And it pulls like 10 - 15 and 5 sitting right next to the router and connected to it and not a satelite. Of course on the satelites almost unusable for anything but web browsing. Tried essentially every chanel without a noticeable difference.
The Arris device is a combo modem/router and wifi is generally turned off but if I turn it on from the same location I pull about 50 / 40. Not great but damn better than the Orbi itself. Of course that only works in the room the router is in and is impractical.
Haven't reset it. Anything else I should be looking at?
Thanks
  • FURRYe38's avatar
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Power OFF RBR and RBS for 1 minute then back on?
    I would factory reset and setup from scratch at some point...
    • Retired_Member's avatar
      Retired_Member
      :smileymad:
      • colinson's avatar
        colinson
        Tutor
        Yeah that cut and paste reply in every post of this ilk not much help here.
    • colinson's avatar
      colinson
      Tutor
      Yeah, I've seen that cut and pasted advice and questions before.
      Most of those are answered in teh post. But I did also try turning off Fast Roaming 20mhz/40mhz coexistence.
    • colinson's avatar
      colinson
      Tutor
      I'll refrain from making generic comments about Orbi (although def making them under my breath) but Orbi really didn't work for me.
      Reset and went through set up again without much improvement in performance.
      So I bought an eero pro and two Beacons. And out of the box man, wired 800mbs compared to 400 for the Orbi and wifi coverage of 200 - 300 throughout the house compared to 15 or less for the Orbi.
      I don't know what the difference is but for my home and circumstances eero >>>>>>> Orbi.
      Anyway, if anyone wants an RBR20 and three satellites, just shipping. Send me a message
