odweik
Aug 20, 2023Aspirant
RBR50 | Firmware Upgrade
Dear All,
i need help am not able to upgrade firmware to the latest version
here below my router detaills
| RBR50 | RBR50 | V2.3.5.30_1.2.13 |
The most recent firmware for the RBR50/RBS50 products is V2.7.5.4
https://www.netgear.com/support/product/rbr50#download
This Netgear article explains how to download the firmware and manually load it to the router and satellite(s):
- odweikAspirant
Hello,
i have manual and i used as AP
Don't forget, a firmware download comes in a zip file that you have to unpack.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- KevinLiTNETGEAR Moderator
Hello odweik ,
Welcome to the NETGEAR Community!
I understand that you are having difficulties upgrading your RBR50 to the current 2.7.5.4 firmware version. In some cases, users find that updating the firmware in increments enables the RBR50 to install the most recent firmware. Please download FW version 2.5.2.4 then firmware 2.7.3.22 then attempt to download FW version 2.7.5.4. To find the download files for the firmware versions mentioned above please navigate to the link below and then click on 'View previous versions' at the bottom of the page next to the plus sign.
RBR50 Firmware download page:
Orbi RBR50 | WiFi System | NETGEAR Support
For step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comPlease keep us updated to the progress of this issue!
Best,
Kevin
Community Team
- odweikAspirant
it is show th below
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
Hello odweik ,
Please ensure that you are using to correct file for your router and your satellites. The firmware for the satellites will have RBS50 as the downloaded zip folder name. The firmware for the router will have the name RBR50 in the downloaded zip folder name. Once you open the zip folder the name of the firmware will also say RBR50 or RBS50 followed by the firmware version. Please ensure that you download the firmware for the satellites before downloading the firmware for the router. For example, upgrade the satellite to the next firmware version then the router. Then continue to download the following firmware in the same order.
Please navigate to the link below for both RBS and RBR firmware files:
Orbi RBK53 | WiFi System | NETGEAR Support
Best,
Kevin
Community Team
- odweikAspirant
Hello
it is from ISP Services
