pbarham's avatar
pbarham
Apprentice
Feb 22, 2021
RBR50 Can't check for firmware updates
My RBR50 no longer seems to be able to check for firmware updates and says "Service Unreachable":
Any ideas on how to fix this?
  • CrimpOn's avatar
    CrimpOn
    Alas, "in-line" images inserted with the Photos icon are not visible until approved by a forum moderator.
    Images attached to a post using the "Browse" button in the lower left are available immediately.
    • pbarham's avatar
      pbarham
      Apprentice
      vajim wrote:
      how are you checking...pc login or app?
      Same with both.  The screenshot was from the web admin interface.
      If I use the iPhone app it says "checkig for update - this may take 5 minutes" and then tells me that checking for updates failed.
      • vajim's avatar
        vajim
        Master
        perhaps reboot all...modem, router, router, sats....and see if that helps
  • FURRYe38's avatar
    This would be a configuration your modem or ISP services not allowing Orbi to check it's FW update services.
    I can check with mine and get thru just fine and works for me. My RBR is double NAT'd as well:
    • vajim's avatar
      vajim
      Master
      I called COX and they said no way on their end..nice try
      What does that mean when you say?..."I can check with mine and get thru just fine and works for me.."
