jprotzel
May 18, 2019Aspirant
RBR50 Connectivity Problems
Hi. I'm new to this forum. I purchased an RBR50 with one satellite last September (2018). I've had no problems until about 6 days ago. I use Spectrum internet service. Until a few days ago i was using a CISCO DPC3208 modem. I started getting spotty service - service was dropping and then coming back. I called Spectrum and they did a speed test which showed the service was fine. They suggested it was a problem with the router. I updated my ORBI firmware to V60 from V44. This did not help. They recommended upgrading my modem to see if it helped with the service. The new modem is a Hitron Technologies E31N2V1. I still have the same problems. They did another speed test and said the service looks fine coming into their modem. I am at a complete loss. Any assistance would be invaluable.
Thank you.
Jeff
Could you describe how you detect service being spotty? How frequently does this occur? (several times an hour? twice a day? etc.)
- jprotzelAspirant
I have service but it frequently takes much longer to load pages and, most importantly, the service drops entirely. This happens frequently - it just happened while i was typing this reply. I can't be on the internet for more than 5-10 minutes without slow or dropped service.
Thanks. So, this is a desktop computer (laptop? tablet? phone?) connected to the Orbi how (wired? WiFi?) So, service drops "while you are typing", but how do you know? Does the WiFi icon suddenly get an exclamation point in it indicating "no internet"? Do you use Microsoft Outlook and see the message "Unable to connect to server"?
For example, if it happens to a wired desktop every 5-10 minutes, my first step would be to unplug the Orbi, wire the desktop directly to the Hitron, (restart the Hitron), and uset the desktop as before.
You mention Cisco and Hitron and then Spectrum says "their modem" is OK. There is not another device in addition to the Hitron is there?
Intermittant problems are really tough to diagnose, which is why it seems important to identify whether it is the Orbi or "something else" that is causing the problem. The awkward part of all this is totally disrupting the entire family during the investigation. For example, I always keep my old WiFi router when I purchase a new one so that I can swap it back in and see what happens. (Not great if the Orbi has allowed more devices to be connected from farther away.) If another WiFi router has the same issue, then it's not the Orbi. If it doesn't, "aha". That's why I suggest connecting directly to the modem for an hour. If that works perfectly, then it's not Spectrum.
- jprotzelAspirant
I did a factory reset and the problem persists. I'll try to connect with an ethernet cable directly to a laptop. I'm very frustrated at this point.
Be sure to power OFF the ISP modem for 1 minuted while you factory reset the Orbi. Then power ON the modem and let it sync.
I would swap out LAN cable between the ISP modem and orbi as well. CAT6 is recommended. Shortest length possible.
