JitM
Dec 24, 2020Aspirant
RBR50 firmware update
I have got following email from Netgear for my RBR50.
We've Enhanced Your Product's Security.
Please Update to the Latest Firmware.
But when I check for updates from app it shows no new firmware is available.
I am on V2.5.2.4 not sure if I am missing any important updates in UK.
Regards
Regards
Be sure to make a back up configuration to file for safe keeping on the RBR. Helps save time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- vajimMaster
Regards1. forget the app. IF you must check, try via PC login
2. IF it were related to an actual security vulnerability then NG would auto push it. No action required.
3. IF you want to upgrade the choice is yours with caution as always since these firmware release are known to have bugs
Next version after v4 is v40:
It's one that may have not been put up on the auto update servers so it may not appear as a notification on the RBRs web page.
v104 is also available. it's on the auto update server however you'd have to manually update to v40 I believe first to see v104. Or you can manually download and manually update to v104 directly with a wired PC and web browser:
Or you can keep what you have loaded as well. Up to you though.
Regards- vajimMaster
FURRYe38 wrote:Next version after v4 is v40:
Proceed with caution and ask yourself why this may not appear as a notification on the RBRs web page and WHY users in here keep posting stuff like this???
- JitMAspirant
Thanks to All who responded this thread.
I have got new iphone app update of Netgear and after that I can see 2.7.2.104 version available to update. I have added the screenshot. I will try it over the weekend.
Thanks
- jwh49Aspirant
After installing the latest firmware I can no longer login to the router. It will not accept my passords or the answers to my security questions.
- alokeprasadMentor
Strongly advise to use the web interface of the RBR50 instead of the smartphone app if you proceed.
How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
- jwh49Aspirant
The firmware update was successful since my WiFi network is up and running after applying it using the updated Orbi iPhone app. I just cannot login using the correct password, serial number and secuity question answers.
