KShivum's avatar
KShivum
RBR50 Seems like we are hitting max devices
Hi, so recently we ran into an issue where a lot of devices aren't able to get an internet connection but are connected to the internet, but when a device disconnects another one gets a connection. I would understand if we had 200 devices but we have 27
    Sounds like maybe you are out of available IP addresses.
    Check your DHCP settings to make sure you allocated enough IP addresses.
    Also check your subnet mask as it also determines how many IP addresses you are allowed to have.
    • KShivum's avatar
      KShivum
      So I changed the Subnet mask to 255.255.0.0 but I can't change the ending IP address past 192.168.1.254, the 1 is locked
      • Mikey94025's avatar
        Mikey94025
        Hero
        This is not a good idea.  Leave the subnet mask at the default (255.255.255.0) until you figure out what the root cause is.
        If your DHCP range is big enough, i.e., the starting IP and the ending IP are well-separated then you should have no problem with 27 devices.  For example, I have 192.168.1.2 to 192.168.1.200.
        We must look elsewhere for why your system is behaving differently from most others.  What settings did you change from the default?
        Also, we need to know if IP address allocation is the problem or not.  Can you use a computer, like Windows and Mac, and reproduce the problem of "aren't able to get an internet connection"?  Exactly what happens -- You can't ping the router IP, or you can't visit websites in the browser, etc.?
    • KShivum's avatar
      KShivum
      Also all of the computers are getting IP's but still aren't getting a connection, is that still correct?
  • FURRYe38's avatar
    Do you have just the RBR or is there a RBS as well. If you only have the RBR, then you maybe running into a bandwidth issue with having that many wifi devices connected to just 1 source. You may need a RBS to help spread and share the load. There are more connections per device then just 1 connection.
    • FURRYe38's avatar
      Oops i see you mentioned a modem and RBS. My bad.
      What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
      https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
      Has a power off for 1 minute then back on been performed since last update?
      • KShivum's avatar
        KShivum
        Sorry for late reply, but yes I have reset and now I have changed the router orbi with a new one. Internet connection is still dropping
    • Mstrbig's avatar
      Mstrbig
      Master
      FURRYe38  He said:
      So it goes from an Artist Sb8200 to a RBR50 Router which has an ethernet into a switch and has two satillites, an RBS20 and another RBR50
  • ISP said it wasn't their problem, internet keeps disconnecting now but I can't completely test if the exact same issue is still happening
    • FURRYe38's avatar
      Try adding just 1 RBS now.
      • KShivum's avatar
        KShivum
        One of them is less than 30 feet, but the other isn't, but we will probably change routers, We've had way too many issues with the Orbi routers and most of my family believes that mesh routers don't work at this point
