Shayzeke's avatar
Shayzeke
Follower
May 20, 2022
RBS50 Add on Satellite
I have an existing RBR50v2 router with one RBS50v2. I’m trying to add another RBS50 satellite that I purchased from eBay and I can’t get it to connect. Do I have to reconfigure the add on which appears to have a different network name and password to make it work?
  • Most users get out a paperclip and do a Factory Reset on the new satellite, then follow the instructions to Add Orbi Satellite.
    • CrimpOn's avatar
      CrimpOn
      Guru
      p.s. There is nothing to configure on satellites. They get all configuration from the router once they are sync'd to it.
  • Sometimes it helps to hardwire it in and sync it. once its added, you can try disconnecting it
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello Shayzeke,
    I understand that you are having issues connecting your third-party purchased RBS50 to your RBR50. All that is required for this device to sync to your RBR50 is a factory reset. After you have conducted a factory reset please navigate to the link below for instructions on how to sync the satellite to your existing network:
    How to sync Orbi router and satellite:
    https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
    Please let me know if you have any additional questions!!!
    Best,
    Kevin
    Community Team
