treadpool
Oct 30, 2019Tutor
RBS50 blinking white - cannot connect
My Orbi satellite is flashing white and I'm not sure why. I've been having sporadic network problems since I upgraded the firmware on the router. Unfortunately I upgraded the firmware on the router before the satellite which I now know is opposite of what you're supposed to do. Unfortunately it didn't say anywhere during the process that I should start at the satellite first, so I fear that it's bricked. The satellite doesn't show up as a device on the router I've tried syncing it normally I've tried a full reset of the router and doing a reset on the satellite with a pin. I've connected a Windows laptop directly to the satellite via ethernet and ran arp -a to see what IP it gives, but it's just 169 type addresses so I can't even use TFTP to load a firmware.
What are my options? This setup is only 1.5 months old.
Try another factory reset on the RBS with a wired PC connected to it. Wait about 4-5 minutes. IF the RBS is still working, the PC will get a IP address. You can access the RBS web page at 192.168.1.250 with a web browser. If you can get here, load the FW file to the RBS. Factory reset the RBS and setup from scratch.
Thanks. To be clear, what are the steps for a factory reset for the satellite? I've read various versions of the steps to take. What I have tried is:
- Insert paperclip and hold for 30 sec
- While still inserted, unplug the power
- While still inserted, plug in power and keep it there another 30 sec
That seem right?
While plugged in to the power, press the back button for 15 seconds then release.
treadpool wrote:
I've connected a Windows laptop directly to the satellite via ethernet and ran arp -a to see what IP it gives, but it's just 169 type addresses so I can't even use TFTP to load a firmware.When a product is unable to get an IP address, it is common for them to create their own "169.x.x.x" address. In order to tftp firmware in that situation, the laptop has to be given an IP that is in the same subnet. i.e. Go into the Network and Sharing Center and change the ethernet port from DHCP to "Static IP" and give it a "169.x.x.x" address with subnet mask 255.255.255.0. Then connect directly from laptop to satellite. When the process is over, the laptop has to be reconfigured to DHCP for it to work on your network again.
The whole tftp process is a chore, what with messing with the network settings. I have actually done this with a RBS50 satellite, so I know it is possible.
Hopefully a reset and connection with the wired PC to the RBS will be all they need. Hopefully.
- Ok so the simple reset didn't work. Resorted to TFTP which was successful and the img file was transferred. What am I supposed to do next? There's no ring light pulsing anymore and the green power led is solid. There's no response when I press the Sync button.
