ChargerMan426's avatar
Feb 20, 2019
RBS50Y not syncing
Just purchased a RBS50Y to add to my RBK50 sytem.  When I try to sync I always end up with a solid magenta light.  I've tried moving the satellite closer, futher away, resetting it, powering it on and off, etc.  I've tried using the hard sync button on my router as well as trying through iOS and the web portal.  Please help!
    • ChargerMan426's avatar
      ChargerMan426
      Tutor
      FW on the router is V2.2.1.210.
      Sysco DPC3010 is what the current modem is.
      Going through your link now but given the RBSY has no ethernet port how would I be able to hook into it to force an update?
      • FURRYe38's avatar
        Ok, I forgot about the RBSY not having a port. Hmmm...
        I think this maybe something you need to contact NG support about.
        If you reset the RBSY and trying to sync it while in the same room and it's failing to show a BLUE led status and only PINK, seems that the RBSY isn't getting connected correctly. I know there are two modes the RBSY work in, Orbi and and Orbi Extender Mode. There are two varients of FW for this unit.
        Blanca_O
    If you have Daisy Chain enabled then the RBS50Y will try to connect to either the router or the satellite in your existing RBK50.
    Please disable Daisy Chain and try the Sync again.
    • When I chated with techsupport they said the unit is bad and I needed to return it.  I currnetly only have the RBR plugged in so the new RBSY only has the RBR to comunicate with.
      • FURRYe38's avatar
        Would be best to return it and if you can get one from Amazon, then that unit should be covered under NG support and warranty.
