sdunnin68's avatar
sdunnin68
Satellite Connection Status
Is there a way to determine what the connection status is between router and satellite? Devices are showing as attached to the Satellite on the Attached Devices page. Not really sure if I can tell if the placement is optimal or not. I assume it is ok becuase the Satellite LED ring is off. The Router ring slow blinks magenta but that scenario does not seem to be covered in the LED Behavior section of the manual and I don't really know what that means.
  • This is my gripe about the RBS50 - it needs its own log in page just like the router has. Even if the router controls all its actions, it would be nice to be able to log on to it while it was live and graphically see what speeds it is pushing out, what directions, what bands, and what it is connecting to. That way you could move it around for best placement. Once the lights go off you really have no idea if the satellite is doing anything.
    • st_shaw's avatar
      st_shaw
      Master
      A log in page is already there with some of the data you want. You just need to connect to the satellite IP with a web browser.
      • Jryan619's avatar
        Jryan619
        Star
        Thank you very much, I guess that's why we come here! I know have three book marks set up, one to take me to the Router Log in, one for the Satellite log in, and one for my ISP's set top box / high speed modem log in.
        This may sound like a silly question, but I could not find the answer on line. Do you know if there is a certain direction the router and the satellite each broadcast their web of wifi? Does it shoot out through the top, the front, the back, or in a circle? Just want to know if the front face it the Orbi needs to be aimed in one direction.
  • I having similar problems with the satellite. It blinks amber then turns solid blue. I looked in my devices connection but it only shows my router and other devices. Except for my satellite.I live at 1500 sq ft townhouse which is three floors. Router located on first floor and sarellite on third. What's the deal?
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello socalgas
      Have you tried to move the Satellite to the second floor and see if it will connect?
      DarrenM
  • If you watch the satellite for about a minute after reconnecting you should see the final color.  It's kind of a pain and I don't know how accurate it is.  Mine was blue, when I finally caught it.
    After that you can go under Advanced -> Advanced Home -> Internet Port -> Show Statistics.  At the bottom you'll see Internet Backhaul.  Mine shows 1733 and moving it a bit hasn't changed it so again, I'm not sure how accurate it is.  The Rx and TX Bytes don't look correct for any of my radios.  After 20 hours I’m showing 7 total for b/g/b, 159 total for a/n/ac and 124 million for backhaul.
    • sdunnin68's avatar
      sdunnin68
      I definately see Tx and Rx counts incrementing for the Backhaul so that must mean they are working. Connections with Satellite are strong and have good speed. Router still pulsing magenta so I don't know what that means though.
      • loomis1975's avatar
        loomis1975
        Luminary
        So, router is continually pulsing just magenta color, but you have a valid IP address from modem/isp, Internet Status says "Good" on the router's home page, and you have access to the internet?
        That is definitely not what the LED rings are suppose to do.  If everything is normal, lights are OFF on both router and satellite.
        Might want to open a support ticket.
        From Netgear KB article:
        what-do-the-leds-on-my-orbi-mean
        Pulsing magenta. Your Orbi router ring LED might pulse magenta for the following reasons: the WAN port link is down, the router is unable to get the IP address from the modem or ISP, or the router is unable to connect to the Internet.
      loomis1975
      Luminary
      The 1733 for the backhaul appears to be a "label" and not a moving statistic, just like the 400 and 866 above it for the 2.4 and 5 ghz.
