Danmccune
Nov 11, 2020Tutor
Slow LAN/Fast WiFi on Orbi RBK33
I am getting about 50% of my availble bandwidth using the LAN port on my RBR40 Orbi Router. My internet is 1GB fiber.
If I take the ethernet cable from the WAN port of the Router and plug it into my laptop, I get consistent speeds around 800Mbps.
If I plug my laptop into one of the LAN ports of the Router, I get consistent speeds around 400Mbps.
Anyone else having this problem? Is there a configuration setting that might be the culprit?
Firmware on the router?
what ont/gateway is it connected to?
Make sure parental controls, traffic monitoring, and access control are disabled. If they were enabled, disable them and reboot the router. Then try.
Firmware V2.5.1.22
ONT: AT&T BGW210 (fiber)
Parental controls, traffic monitoring, and access control are disabled, and have always been disabled.
Rebooted and reset multiple times. I've been troubleshooting for a week with no success.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
https://community.netgear.com/t5/Orbi/Configuring-ORBI-RBR50-with-ATT-Fiber/m-p/1999922#M106198
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
- harrycharlesopAspirant
plemans wrote:Firmware on the router?
Make sure parental controls, traffic monitoring, and access control are disabled. bkexperience If they were enabled, disable them and reboot the router. Then try.
Thanks, that really helped.
I configured the ONT for passthru, and reset the Orbi Router, but I am still having the same problem.
