jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre reference to discconections but that sounds like a promising fix.
Wonder if and when people update if they post if they have had discconnections (ios or Andriod) since installing V1.9.1.12 then we may know if its been fixed permanently
- Can you link to the release notes? Not seeing it on the downloads page yet.
- jmbarbsApprentice
Don't think i can now as it came up in a popup box when clicking hyperlink of the version number beore i clicked the update button. As you say its not been updated on the netgear downloads page. From previous versions this is usually updated on the website 24 hours after its available on the router
- tubastankApprentice
Netgear,
When you release a new verion of firmware it would be nice to include release notes. I have nothing but issues with Parental Controls and devices keeping them persistently. I have to reboot the Orbi every couple of days. For example, I have "None" set up for my laptops (MacBook & Dell) but sometimes when I launch IPVanish to create a VPN connection, the VPN client errors. After I reboot the Orbi all is good for a couple days.
Anyone know if firmware version v1.9.1.12 includes fixes to the Parental Controls to keep them persistent....as it should be design?
 - rivetsApprentice
Still dropping connections on the household iPads, so that's not fixed.
- Ts937kmApprentice
So far no drops on my iPad Pro or iPhone. Historically in the morning I would have issues or anytime I left the iPad alone . Updated router and 2 satellites to 1.9.1.12 yesterday. I also moved my satellites to the end of my house on the main level and the router is in the middle of the basement seems like they are supposed to be 40-70 feet from each other correct?
- Ts937kmApprentice
Oh and
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enable MU-MIMOAre disabled under avanced - wireless settings.
 - About how far were you able to place them from each other? Mine are currently about 40 feet, considering trying to move them further.
- Ts937kmApprentice
I would guess about 40 ft from the router to each satellite. Hard to measure with being on a different level plus going through multiple walls and a floor.
With a couple of different tools my whole house is solid green on a wifi heat map.
- Ts937kmApprentice
Btw. Still stable. No iPad or iPhone drops today. Was gone for several hours today and iPad hasn't had any issues. Historically it would have complained about no wifi already.
 - Ts937kmApprenticeCouple things I would try.
Do you have any other wifi on? Like uverse, etc. If uverse how is your network configured? Just hanging off the uverse router or is it a different network bridged (and Different IP range). I'm on at&t gigapower or at&t fiber I think it's called now.
I had reset my network settings on my iPad and iPhone and then rebooted them. And then reconnected. Trying to troubleshoot. As it used to be on a different router with same name.
I would fully reboot the orbis. Turn them off. Boot up the router. And then the satellites.
Make sure beam forming and mmu are turned off before the reboot. Last two options on the advanced wireless settings pages.
Is your orbi satellite at least 40 ft away from the orbi router.- rivetsApprentice
No idea what uverse is, so I don't have it :-) (I'm in the U.K.)
beam forming and MIMO are off. I have Sonos. But it is on channel 11 and Orbi is on 1. Power on 2.4 set to 25%.
router and satellite may not be 40 ft apart. I will probably try moving it up a floor tomorrow. Everything has been rebooted and reset multiple times. I'm constrained by where the copper enters the building and the depth of the house.
yup correct location is the key here , too close and the clients will get confused , too far apart and the clients may disconnect in the middle
 - Ts937kmApprenticeCurious why you care which one the device is attached to? As long as performance is good? What are you trying to troubleshoot?
I'm just happy they are making real progress on the disconnect issue.- tubastankApprentice
Because knowing which unit (sat or router) your devices are connected to will help in troubleshooting. I think you answered your own question. :) I personally haven't been having disconnects but I am having other issues. Parental Controls & Airprint not staying persistent. The more you know about your network the better position one is in troubleshooting.This is basic information Netgear could be providing and it shouldn't take much to fix.
My Orbi system was purchased at Costco and consists of 1 Router and 2 Sattelites. The Router is in my unfinished basement, connect to my cable modem (Cox Internet). My main floor Orbi is probably 25 feet from the router (up next level and across the family room). My Second floor Orbi is on the other side of the house and probably 40 feet away. I could be wrong on the distance as I haven't measured but am estimating. Transmit Power Control on the 2.4Ghz signal is set at 25%, 5Ghz 100%. Implicit Beamforming & MU-MIMO are disabled.
Hello all,
First time post,
I am a systems and network engineer, and pretty much a technology nerd. I purchased my orbi in January 2017 to see what all the bells and whistles were about.
To address the original question in this post and not hijack it, your wireless connection stability issues are shared by me. I have been running several out-of-band tests and can reliably say that there are issues with connections and overall usability and functionality of the product. I am running the 1.9.1.12 version on the RBS50
I had one engagement with tech support and when I provided some technical insight into the problem, they were having me jump through the flowchart to keep me busy. "Have you turned it off and on again? Did you wait the 35.2 seconds? Let's reflash the firmware....and now again."
I personally do wireless security cameras and weather stations. The weather station reporting and the security cameras don't have a reliable or fast enough wireless connection to be useful. I can barely do 1 fps with one camera.
I have since added a $49 router outside of the orbi (in front of my orbi system) so that I can see if there is a difference. The $49 router was limited in features but was able to get 10 fps on the camera and kept a 30 second connection update to the NWS and NOAH.
The lack of any documentation in the releases is disturbing. As a previous person mentioned....Where are these mystery documents? I would expect that if it automatically downloads and installs, they could at least present a "What's new and fixed" section in the web interface.
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices Enable MU-MIMO While I appreicate what this says, I can with some certainty say that the first option is not needed in most newer setups. Sounds impressive, isn't all that useful anymore.
Having used some of the nighthawk routers in the past, I must say that the orbi is a huge feature and functionality disappointment. The only thing that is impressive with this is the simplicity and coverage area.
For all the others saying stuff about the firmware version, you are probably running into a lot of problems that we all are. I'd suggest that you start another post/thread and file the bug.
 - I'm still having WAN disconnects after upgrading to Firmware V1.9.1.12.
It's actually even worse than before (I think). Today alone I've had about 10 WAN disconnects (~15min each). I have sent debug logs to netgear and they are going to remote access the router to take a closer look at it (I've been having trouble for +4 months).
One can say that I'm not that far from replacing it with something else as it obviously doesn't work on Mondays, the Month of February, Thursday's before 9 o'clock or during happy hours on Fridays if my favorite team is on TV (or just with my ISP).- Ts937kmApprentice
That sucks. I have not had one disconnect since the upgrade.
All of my apple stuff is currently running the latest firmware except for my watch which is on a beta built.
No other wifi on in my house. Disabled att uverse/gigabit wifi on their router.
I have the the orbi router and 2 satellites running 1.9.1.12. Router in the middle of the basement. Satellites about 40 ft away from the router. At each end of the house on the main level. Only have about 20 devices connected to wifi. Also have a ton of zigbee, zwave and Arlo camera wireless running.
Hopefully they will figure out something for you soon
 - rivetsApprentice
Moved the satellite to almost as far as is physically possible in the house from the router. No drop outs, so fingers crossed. Will try re-enabling beam forming etc.
 - Ts937kmApprenticeHope so.
I read somewhere that beam forming was disabled last forming because of drop out issues. So I am going to leave it off for a bit.
I wonder if there is a way to tell optimal placement of the devices. To make sure the satellite has good connectivity. Would be a nice feature. - ricblueTutor
My Orbi Base Station is upgraded to v1.9.1.12 BUT my two Satellites are both stuck on v1.8.0.6. The "Check for Updates" button on the Orbi web UI (at 192.168.1.1) lists the two Satellites with the old v1.8.0.6 BUT shows "Please wait a moment' next to each and never offers the ability to upgrade them.
If I log into each Satellite (for me at 192.168.1.3 and .4) then I can only do a firmware update IF I can upload a file from my computer - BUT the v1.9.1.12 upgrade files aren't available on the Orbi Support website/downloads area.
Any thoughts? My system seems reasonably stable but surely this isn't ideal, running different firmware versions on the Base vs Satellites. v1.9.1.12 upgrade glitch if it didn't do the Satellites as well when the Base was updated??
Any thoughts? Suggestions?
Thanks!
Richard
Wifi disconnects not fixed here with V1.9.1.12. Running Orbi in AP Mode. Turned down 2.4GHz transmit power to 25%. Implicit beamforming and mu mimo disabled. Today 3 non-moving iOS devices got disconnected in 10 minutes, each 3 times! The devices were 1-3 meters from satellite away (in visual range).
I did some RSSI analysis: Seems that the devices get kicked out from 5GHz band while the signal is strong, but the 2.4GHz signal from identical Orbi is equal or slightly stronger. It seems not to be a steering problem between router and satellite since my signals are well separated (satellite client signals are strong while router client signals are very weak and vice versa). Turning down the transmit power of the 2.4GHz band to 25% helps for medium/long distance to the router/satellite as workaround, but not for narrow distances. Playing with the 2.4GHz transmit power "controls" at which distance the disconnects are typically happening.
So the root cause is a band steering bug between the 5 and 2.4GHz bands. Which is very disappointing for such expensive hardware, especially if you consider that client side band steering (without expensive hardware) works more reliable and Netgear didn't fix this bug for months (while very aware of the problem).
Slowly but surely I conclude that Netgear can't fix that problem and I should return the defective by design devices...
If all your devices support the 5GHz band I recommend disabling the 2.4GHz completely as a workaround (and if you don't need to cover the very far distance which 5GHz can't reach). I have some legacy devices so I can't turn it off.
Turning down the transmit power of the 2.4GHz band to 25% helps for medium/long distance to the router/satellite as workaround, but not for narrow distances. Playing with the 2.4GHz transmit power "controls" at which distance the disconnects are typically happening.So the root cause is a band steering bug between the 5 and 2.4GHz bands. Which is very disappointing for such expensive hardware, especially if you consider that client side band steering (without expensive hardware) works more reliable and Netgear didn't fix this bug for months (while very aware of the problem).
