NikMan
Dec 06, 2018Aspirant
Using Orbi as AP with managed switch
Hi All,
I'd be grateful for any advice! I just bought an Orbi with 2 satellites as my (three) old Netgear PoE WAP's have been playing up recently. My set-up is-
1. Virgin media Superhub 3 in ...
- Dec 10, 2018
Hi All,
I've managed to get the Orbi working with my switch etc. I don't if I this was entirely necessary but what I did was -
1. changed Orbi back to router mode
2. Synced both satellites
3. Changed Orbi router back to AP
4. Plugged it into the LAN port and waited a while!
I think the original LAN port I was using was faulty, which clearly caused a lot of my original confusion/problems.
It all seems to be working now, with my Netgear R7000p acting as Router. I have one of the Satellites also connected to the switch via a LAN port as well - which I am assuming will help the stability of my MESH network? I am still trying to understand some of the new terms associated with MESH WiFi (ethernet backhaul/daisy-chaining etc) - when I logged into the Orbi it said my backhaul was good?
However! Just discovered this morning that one of my Sonos boxes can't connect to the Orbi satellite WiFi. I did a quick Google and discovered lots of people have had similar problems. I am going to have a play and try and get it working - if not then I will have to connect the Sonos boxes use a LAN connection.
Thanks for all the help/advice!
NikM
p.s. - I did log into my Netgear Switch, and I think the "IGMP protocols" were already disabled?
Dec 06, 2018Guru - Experienced User
What is the mfr and model of the managed switch. Others have said to disable IGMP protocols on the managed switch to get it working with Orbi systems.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123
Green Switch: https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394
What FW is currently loaded?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Daisy Chain needs to be disabled for wired back haul connected satellite(s).
